[gdal-dev] GDAL 2.3.1 on linux disregarding nodata values
Tom van Tilburg tom.van.tilburg at gmail.com
Fri Jul 6 06:54:36 PDT 2018
 Got myself a build that has the correct proj version now (./configure
--with-proj) so it doesn't segfault.
I can confirm that the nodata values are correctly dealt with now :)
Still battling the linked gdal version though, will post when I dealt with
that.
Tom
On Fri, Jul 6, 2018 at 2:09 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 6 juillet 2018 14:00:16 CEST Tom van Tilburg wrote:
> > I just did a fresh build of trunk (2.4.0) but noticed 2 issues:
> > 1. The installed version in /usr/local/bin is still version 2.3.1:
> You may have to defined LD_LIBRARY_PATH since it probably links against
> your
> system libgdal
> Otherwise you don't need to install the master, but just make and source
> the
> scripts/setdevenv.sh that will set PATH, LD_LIBRARY_PATH, GDAL_DATA and
> PYTHONPATH to appropriate values in the built tree.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180706/f3f651e7/attachment.html>
