[gdal-dev] WMS, blocksize and black lines
Chris Smemoe csmemoe at aquaveo.com
Mon Jul 9 22:04:27 PDT 2018
Arno,
I suspect the black lines has something to do with using the -projwin
argument to gdal_translate along with the DataWindow tag information in the
XML file.  The following XML works fine for me with the following command
line: "gdal_translate wms.xml test.tif"
<GDAL_WMS>
   <Service name="WMS">
     <Version>1.1.1</Version>
<ServerUrl>https://gis.apfo.usda.gov/arcgis/services/NAIP/Illinois/ImageServ
er/WMSServer</ServerUrl>
     <ImageFormat>tiff</ImageFormat>
     <Layers>0</Layers>
     <BBoxOrder>xyXY</BBoxOrder>
     <SRS>EPSG:4326</SRS>
   </Service>
   <DataWindow>
     <UpperLeftX>-89.0</UpperLeftX>
     <UpperLeftY>42.0</UpperLeftY>
     <LowerRightX>-88.0</LowerRightX>
     <LowerRightY>41.0</LowerRightY>
     <SizeX>1024</SizeX>
     <SizeY>1024</SizeY>
   </DataWindow>
   <UnsafeSSL>true</UnsafeSSL>
</GDAL_WMS>
Chris
-----Original Message-----
From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Arno
Gerretsen
Sent: Monday, July 09, 2018 12:01 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] WMS, blocksize and black lines
Hi all,
I'm trying to create a WMS XML to access some WMS data in GDAL. But I
get black lines in the resulting image. I have found out that if I
reduce the size of the BlockSize in the WMS XML that the lines get more
narrow, but the download speed of the images also reduces a lot. Am I
missing some setting here to make it work?
This is the XML file I use:
<GDAL_WMS>
er/WMSServer?SERVICE=WMS</ServerUrl>
     <Layers>0</Layers>
     <ImageFormat>image/tiff</ImageFormat>
     <Transparent>FALSE</Transparent>
   </Service>
   <DataWindow>
     <UpperLeftX>-91.562525</UpperLeftX>
     <UpperLeftY>42.562525</UpperLeftY>
     <LowerRightX>-87.437470</LowerRightX>
     <LowerRightY>36.937474</LowerRightY>
	<SizeX>370834</SizeX>
     <SizeY>625056</SizeY>
   </DataWindow>
   <BandsCount>4</BandsCount>
   <BlockSizeX>1024</BlockSizeX>
   <BlockSizeY>1024</BlockSizeY>
</GDAL_WMS>
And this is a sample call that shows the black lines:
gdal_translate -projwin -88.0 42.0 -87.99 41.99 wms.xml test.tif
With regards,
Arno
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
