[gdal-dev] Trac page on compiling GDAL with FITS support
Chiara Marmo
chiara.marmo at u-psud.fr
Fri Jul 13 02:59:31 PDT 2018
Hello,
Just to let you all know that a page describing how to link GDAL against CFITSIO is now available at
https://trac.osgeo.org/gdal/wiki/FITS
Best,
Chiara
----- Original Message -----
> From: "Even Rouault" <even.rouault at spatialys.com>
> To: gdal-dev at lists.osgeo.org
> Sent: Wednesday, July 11, 2018 6:17:15 PM
> Subject: Re: [gdal-dev] Trac page on compiling GDAL with FITS support (was FITS format not listed in gdalinfo
> --formats)
> On mercredi 11 juillet 2018 17:40:21 CEST Chiara Marmo wrote:
> > Hi,
> > I'm Chiara, as Trent said I'm working on FITS driver improvement in GDAL.
> > I have prepared a documentation page on the VESPA-Europlanet wiki [1]
> > I'm not an official contributor to GDAL code, but I will be happy to
> > contribute to the Trac documentation if I may. May I? :)
> Sure. I'll send you in private message the "mantra" to create a OSGeo user id
> if you don't have one already, and you'll indicate me your id so I can grant
> you wiki page modification right.
> Even
> > Thanks for listening,
> > Chiara
> > [1] https://voparis-confluence.obspm.fr/display/VES/GDAL+with+FITS
> > > From: "Jeff McKenna" <jmckenna at gatewaygeomatics.com>
> > > Sent: Thursday, July 5, 2018 8:18:50 PM
> > > Subject: Re: [gdal-dev] [EXTERNAL] Re: FITS format not listed in gdalinfo
> > > --formats
> > > Trent, is it possible that you record all these steps and hints for
> > > compiling FITS support at https://trac.osgeo.org/gdal/wiki/BuildHints
> > > (i.e. create a new wiki page there and add a link to your build page in
> > > the "External Library Issues" section) That way the steps are recorded
> > > and easy to find (instead of lost in the email archives)
> > > I'm happy to add a Windows section for compiling FITS as well.
> > > thanks!
> > > -jeff
