[gdal-dev] Esri JSON Curves
James Klassen
klassen.js at gmail.com
Fri Jul 13 12:08:17 PDT 2018
Ok. I made that change and it appears to work.
Latest code available here: https://github.com/klassenjs/
gdal/tree/esrijson-curves
On Mon, Jul 2, 2018 at 1:56 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> > In the first two cases (without OLCCurveGeometries set) I see
> > curveToLineString is being called when there are curves in the data, but
> > not on every result page (again curves are relatively rare in the
> dataset).
> ok, then replace the call to OGRMemLayer::SetFeature() with
> OGRMemLayer::ISetFeature() in ogrgeojsonlayer.cpp to shortcut the
> linearization that is done by the generic OGRLayer::SetFeature()
> And you can then remove OLCCurveGeometries
> > In the last two cases (with OLCCurveGeometries set) I see
> > curveToLineString is being called with a different back trace (related
> > to OGRGeometryFactory::organizePolygons):
> That one is fine. It is an implementation detail of organizePolygons()
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180713/91ca1f30/attachment.html>
