[gdal-dev] Compile GDAL with OGDI support on Windows
GUIMMARA, Sébastien (External) [FR]
sebastien.guimmara.external at airbus.com
Wed Jul 18 01:49:47 PDT 2018
I am trying to compile GDAL 2.3.0 with OGDI 3.2.0 library on Windows, but the linking step fails because some libraries (zlib, proj) are present twice (in the OGDI lib, and also in the GDAL build).
In nmake.opt, if I remove the support for PROJ or zlib (to use the ones provided by OGDI), then the linker complains again because some symbols related to PROJ are missing. (e.g _pg_transform, _pg_init_plus...).
Moreover, nmake.opt does not seem up to date with OGDI 3.2.0 (notably the OGDI_INCLUDE path is slightly different).
The OGDI source was taken from GitHub (https://github.com/libogdi/ogdi), but the source taken from SourceForge is identical.
I also noted that GDAL continuous integration (appveyor) does not include OGDI support. Does that mean that OGDI is deprecated ? Is there an alternative for VPF support ?
Thank you,
Sébastien
Please consider the environment before printing this email message.
Ce courriel (incluant ses éventuelles pièces jointes) peut contenir des informations confidentielles et/ou protégées ou dont la diffusion est restreinte. Si vous avez reçu ce courriel par erreur, vous ne devez ni le copier, ni l'utiliser, ni en divulguer le contenu à quiconque. Merci d'en avertir immédiatement l'expéditeur et d'effacer ce courriel de votre système. Airbus DS Geo décline toute responsabilité en cas de corruptionpar virus, d'altération ou de falsification de ce courriel lors de sa transmission par voie électronique.
This email (including any attachments) may contain confidential and/or privileged information or information otherwise protected from disclosure. If you are not the intended recipient, please notify the sender immediately, do not copy this message or any attachments and do not use it for any purpose or disclose its content to any person, but delete this message and any attachments from your system. Airbus DS Geo disclaims any and all liability if this email transmission was virus corrupted, altered or falsified.
Airbus DS Geo SA (325 089 589 RCS Toulouse) - Siege social: 5, rue des Satellites, 31400 Toulouse, France.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180718/e9fc22a7/attachment.html>
