[gdal-dev] Writing geotiff with /vsigs in Python does not work
    Christoph Paulik
    cpaulik at vandersat.com
    Fri Jul 20 03:25:26 PDT 2018
Ok, thank you for the clarification.
Even Rouault writes:
> Christoph,
>> Do I have to do things in a different order or way for this to work?
> /vsigs/ implementation (and other cloud virtual file systems) only supports
> sequential writing, but in the general case, writing a GeoTIFF file requires
> random writing capabilities, particularly for compressed datasets.
> See the "streaming operations" paragraph of http://gdal.org/frmt_gtiff.html
> So you have to create a on-disk file first and then copy it to the bucket.
> Even
Christoph Paulik
VanderSat // Satellite observed water data. Globally. Daily.
Wilhelminastraat 43a, 2011 VK, Haarlem (NL), The Netherlands
W: www.vandersat.com
M: +31 (0) 6 1827 1928
PGP: 8CFC D7DF 2867 B2DC 749B  1B0A 6E3B A262 5186 A0AC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180720/fe6b8a74/attachment.sig>
