[gdal-dev] Use GDAL on AWS Lambda
Matt Hanson matt.a.hanson at gmail.com
Wed Jul 25 07:55:10 PDT 2018
A bit late to the party, but there's also geolambda which works in a
similar manner as the above solutions. It's got the latest version of GDAL
and dependencies, Python 2.7 and 3.6 and packaging scripts for packaging up
your code for deployment to lambda:
https://github.com/developmentseed/geolambda
On Fri, Jul 13, 2018 at 2:17 PM kch <kchin at edrnet.com> wrote:
> Tim's solution worked for me. Thank you!
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180725/ac512c63/attachment.html>
