[gdal-dev] numeric values in VFK driver
Even Rouault
even.rouault at spatialys.com
Tue Jun 5 02:16:55 PDT 2018
On mardi 5 juin 2018 08:12:59 CEST Martin Landa wrote:
> Hi,
> there is an issue with VFK driver when interpreting numeric values.
> Attribute type in VFK data is defined by string like
> &BVLA;PODIL_CITATEL N30;PODIL_JMENOVATEL N30;
> where VLA is layer name, N -> numeric; 30 -> width
> Currently such data types are interpreted as bigint by the driver. But
> the value can be apparently (tested almost on full Czech cadastre
> dataset) larger that bigint in reality, eg.
> &DVLA;...109690709117941111470877379;221486618060854273218000000;...
> Such values are nonsense, but VFK driver has to read them. Currently
> overflowed values are returned.
> I can see only one option: switch to strings. So N30 will be treated
> as string(30) by GDAL. Unfortunately it will influences (due to few
> non-sense values mentioned above) important attributes like ID which
> will be converted from bigint to text attributes.
For >= 19 characters, bigint cannot be used indeed. There isn't much other
choice than storing as a string.
Even
http://www.spatialys.com
