[gdal-dev] About deprecated CRS and the different behavior of EPSGGetPCSInfo and EPSGGetGCSInfo
Even Rouault even.rouault at spatialys.com
Sat Jun 9 03:33:12 PDT 2018
On samedi 9 juin 2018 03:19:30 CEST andreaerdna wrote:
> Do you think it would be appropriate and safe to back port in 2.3 brach the
> commits [0] about the name of deprecated GeoGCSs and GeoCCSs, now that 2.3.1
> version is scheduled?
Andrea,
Those are functional changes that could potentially break code that would rely
on the CRS name without the " (deprecated)" suffix.
Even
> [0]
> - "importFromEPSG(): append ' (deprecated)' at end of deprecated GeoCCS
> (#646)"
> 8cd283e19208fe6e0276adc4e3a7f54fcc30ed54
> <https://github.com/OSGeo/gdal/commit/8cd283e19208fe6e0276adc4e3a7f54fcc30ed
> 54> - "Merge pull request #575 from rouault/deprecated_gcs"
> 01369046d8780d34f722c7011789cda409fe07df
> <https://github.com/OSGeo/gdal/commit/01369046d8780d34f722c7011789cda409fe07
> df> - "importFromEPSG(): append ' (deprecated)' at end of deprecated GCS"
> 2db4413faeeecb81c3c9951a9c8b750d8a9a679e
> <https://github.com/OSGeo/gdal/commit/2db4413faeeecb81c3c9951a9c8b750d8a9a67
> 9e>
> Andrea Giudiceandrea
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
