[gdal-dev] [Gdal-dev] python - reproject a shapefile
Rutger kassies at gmail.com
Mon Jun 11 00:31:18 PDT 2018
Hey,
As you already mention in your post, you didn't specify a SRSfor the input,
that's probably the main issue. Inputs need to be georeferenced correctly.
If you 'only' want to do a reprojection, you could consider using the
bindings to the command line utilities. This would simplify you code a lot,
reducing the possibility of bugs. Something like:
/dsvec = gdal.VectorTranslate('output.shp', 'input.shp' srcSRS=input_srs,
dstSRS="EPSG:32633")
dsvec = None /
Usually you don't have to specify the input SRS, but since yours is missing,
you can assign (overrule!) it like this.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
