[gdal-dev] OGR Spatialite to geopackage
lucvanlinden
luc.vanlinden at gmail.com
Wed Jun 13 12:31:50 PDT 2018
Hi
Even, we had indead a similar question before on the all tables etc with
views.
This howevere is a straight spatialite to geopackge transform equally as
Jukka explained.
I must say we are on a 2.2.0 still.
The listing with tables works (layernames), the straight as in
ogr2ogr -f gpkg output.gpkg input.sqlite
is causing the errors for the view "geom_cols_ref_sys".
(we have not made the transition yet to 2.3.X given the issues we read on
the new srs transform stuff we have to look into thecorrect EPSG 31370, but
this will be another topic once we had time to confiim or not )
Should however the current issues comming from the 2.2.0 version we can
obviously use that in the mean while for this exercise.
thanks once more.
Luc
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
