[gdal-dev] GDAL_GRID Linear: Segmentation Fault
Ian Reese
ireese at linz.govt.nz
Fri Jun 15 14:07:27 PDT 2018
Hi Evan,
Thanks for the heads up. I am running GDAL 2.2.2. I'll upgrade and let you know how it works out.
Cheers,
Ian
________________________________________
Sent: Friday, 15 June 2018 9:55 p.m.
To: gdal-dev at lists.osgeo.org
Cc: Ian Reese; Jeremy Palmer
Subject: Re: [gdal-dev] GDAL_GRID Linear: Segmentation Fault
Ian,
which GDAL version is it ? There has been a bug fix in that area in 2.2.3 :
https://trac.osgeo.org/gdal/ticket/7101
Even
http://www.spatialys.com
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
