[gdal-dev] Esri JSON Curves
Even Rouault even.rouault at spatialys.com
Fri Jun 22 12:51:59 PDT 2018
On vendredi 22 juin 2018 14:38:15 CEST James Klassen wrote:
> I finally got around to doing a rough implementation of parsing ESRIJSON
> with curved geometries.  The code is very rough yet, but works enough to
> import a polygon layer from an ESRI FeatureService into PostGIS with the
> curves intact.  Code is available at [1].
> Main issues:
> I don't know how to detect if there will be curves in the source file
> without first parsing the whole file, so currently I just assume a curved
> geometry type.  This might be a candidate for an open option.
The ESRI Json reader ingests everything in memory and builds the JSon tree
structure, so doing an initial pass by default shouldn't be a big deal.
> My focus has been on polygon layers (because that's the dataset I need to
> read).  I doubt it works outside of polygon layers at the moment.
> I had to enable the "Curve Geometries" capability in the top level GeoJSON
> driver (which may break some things for the GeoJSON/TopoJSON drivers).
If my memories are right, you only need to set it for write support. So
shouldn't be needed there.
http://www.spatialys.com
