[gdal-dev] Kriging Interpolation
Ian Reese ireese at linz.govt.nz
Sun Jun 24 20:19:17 PDT 2018
Hi Gdal,
I'd like to know if it is possible to make Kriging Interpolation part of gdal_grid.  We work with a good deal of scattered point elevation data and neither IDW or Linear interpolations(smooth or not smooth)  produce the desired visual results.  Nor are they fast enough for the density of data we commonly work with. Linear interpolation is a reliable and fast method, however the triangulated results are difficult to work with visually.
For some visual comparisons and reference, here is a link to a folder of sample points(shp) for a test area, two examples of kriged data for that test region, and a BASH script to reproduce IDW and Linear interpolations of the same region.
https://drive.google.com/open?id=1HKbK4wMmVN6JZSvhxBQDub1WXBLE710H
Here is an example of the Kriging method used by ArcGIS:
http://desktop.arcgis.com/en/arcmap/latest/extensions/geostatistical-analyst/kriging-in-geostatistical-analyst.htm
Few graphs explaining best interpolation methods to use with given data.  Gridded vs. scattered.
https://www.neonscience.org/spatial-interpolation-basics
If it is possible, we are curious to know what type of funding would be needed.
Cheers,
Ian
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180625/7f972ccb/attachment.html>
