[gdal-dev] "fixing" CRS for a read-only raster
Even Rouault
even.rouault at spatialys.com
Tue Jun 26 06:58:28 PDT 2018
Idan,
> I have an ECW raster with a wrong CRS (which I believe can't change because
> I don't have the ECW writer license).
Changes in the header don't require a write license
So gdal_edit.py -a_srs EPSG:xxxx your.ecw
should work and modify in place the ECW
Otherwise you can add the -ro flag to the above, and it will generate a
.ecw.aux.xml file with the overriden projection info.
> Is there an option to add an aux/prj file next to it so that GDAL will read
> the correct CRS from the aux file instead of from the ECW file ( i.e. from
> GeoServer/QGIS) ?
> I know I can workaround it with a VRT file but I think it might degrade the
> performance.
For "simple VRT" generated with "gdal_translate your.ecw your.vrt -a_srs
EPSG:xxxx -of VRT", the VRT driver has optimizations to directly forward pixel
requests to the underlying driver with minimal overhead.
Even
http://www.spatialys.com
