[gdal-dev] Specifying NODATA values for the TMS (mini)driver
Even Rouault
even.rouault at spatialys.com
Thu Jun 28 12:57:51 PDT 2018
On jeudi 28 juin 2018 19:42:53 CEST Lucian Plesea wrote:
> >> The contents of a <NoData> tag might be a comma separated list for
> >> multiband rasters.
> >> Would an enhancement request to support this be acceptable?
> >Sounds reasonable to me. Do you intend to propose a PR for this ? Ideally
> >you would do the similar adaptation to the WMTS driver.
> >Even
> It is supported, for all WMS driver flavors. The syntax is:<DataValue
> NoData="10"/> or <DataValues NoData="10 20 30"/> for multiple band, with
> one value for each band.In addition to the NoData attribute, "min" and
> "max" are also handled the same way.
Ah, thanks. This wasn't documented. Just added it.
Except it seems that ZeroBlock() just zeroes blocks, and doesn't use the
nodata value.
Even
http://www.spatialys.com
