[gdal-dev] Missing layers with GeoPDF to MVT conversion with ogr2ogr/gdal 2.3.0
Max Ogden max at maxogden.com
Fri Jun 29 01:02:47 PDT 2018
Hi, I am trying to convert USFS FSTopo GeoPDFs into Mapbox Vector Tiles
like this:
$ wget
https://data.fs.usda.gov/geodata/rastergateway/data/34117/fstopo/340711752_Azusa_FSTopo.pdf
$ ogr2ogr -f MBTILES test.mbtiles 340711752_Azusa_FSTopo.pdf
I'm using gdal git master (GDAL 2.4.0dev-1f6d597, released 2018/06/28) with
poppler 0.64.0.
My issue is that when I view the mbtiles in a webgl map (using $
tileserver-gl-light test.mbtiles) I only see 13 layers, not the 59 I was
expecting. Is it possible to include the vector information in all the
GeoPDF metadata layers when converting to MVT? I tried adding `--config
OGR_PDF_READ_NON_STRUCTURED YES` to the end of my ogr2ogr command but it
had no effect.
ogrinfo shows 59 metadata layers and 13 top level named layers:
$ ogrinfo -mdd layers 340711752_Azusa_FSTopo.pdf
INFO: Open of `340711752_Azusa_FSTopo.pdf'
      using driver `PDF' successful.
Metadata:
  CREATION_DATE=D:20171221174439Z
  CREATOR=Esri ArcSOC 10.3.1.4959
  NEATLINE=POLYGON ((407183.394216688 3775784.59268212,407183.480495386
3790905.61434883,420034.534067471 3790905.80204647,420034.842839467
3775784.26947838,407183.394216688 3775784.59268212))
Metadata (layers):
  LAYER_00_NAME=Other_5
  LAYER_01_NAME=Quadrangle_Extent
  LAYER_02_NAME=Quadrangle_Extent.Labels
  LAYER_03_NAME=Quadrangle_Extent.Labels.State_Outline_-_Default
  LAYER_04_NAME=Quadrangle_Extent.Other_4
  LAYER_05_NAME=Quadrangle_Extent.State_Outline
  LAYER_06_NAME=Adjacent_Quadrangle_Diagram
  LAYER_07_NAME=Adjacent_Quadrangle_Diagram.Other_3
  LAYER_08_NAME=Adjacent_Quadrangle_Diagram.Labels
  LAYER_09_NAME=Adjacent_Quadrangle_Diagram.Labels.Quad_Outlines_-_Default
  LAYER_10_NAME=Adjacent_Quadrangle_Diagram.Quadrangle_Extent
  LAYER_11_NAME=Adjacent_Quadrangle_Diagram.Quad_Outlines
  LAYER_12_NAME=Other_2
  LAYER_13_NAME=Quadrangle
  LAYER_14_NAME=Quadrangle.Other
  LAYER_15_NAME=Quadrangle.Labels
  LAYER_16_NAME=Quadrangle.Labels.Unplaced_Labels
  LAYER_17_NAME=Quadrangle.Labels.Unplaced_Labels.Road_Shields_-_Vertical
  LAYER_18_NAME=Quadrangle.Labels.Road_Shields_-_Horizontal
  LAYER_19_NAME=Quadrangle.Labels.Road_Shields_-_Vertical
  LAYER_20_NAME=Quadrangle.Labels.Road_Shields_-_Default
  LAYER_21_NAME=Quadrangle.Neatline/Mask
  LAYER_22_NAME=Quadrangle.Neatline/Mask.Grid_Labels
  LAYER_23_NAME=Quadrangle.Neatline/Mask.Neatline
  LAYER_24_NAME=Quadrangle.Neatline/Mask.Mask
  LAYER_25_NAME=Quadrangle.Text
  LAYER_26_NAME=Quadrangle.Road_Shields
  LAYER_27_NAME=Quadrangle.Buildings
  LAYER_28_NAME=Quadrangle.Culture_Features
  LAYER_29_NAME=Quadrangle.Drainage_Features
  LAYER_30_NAME=Quadrangle.Large_Tanks
  LAYER_31_NAME=Quadrangle.Survey_Points
  LAYER_32_NAME=Quadrangle.Geodetic_Control
  LAYER_33_NAME=Quadrangle.Recreation/Facility_Features
  LAYER_34_NAME=Quadrangle.Transportation_Features
  LAYER_35_NAME=Quadrangle.Linear_Transportation_Features
  LAYER_36_NAME=Quadrangle.Railroads_
  LAYER_37_NAME=Quadrangle.Linear_Culture_Features
  LAYER_38_NAME=Quadrangle.Linear_Landform_Features
  LAYER_39_NAME=Quadrangle.Boundaries
  LAYER_40_NAME=Quadrangle.Boundaries
  LAYER_41_NAME=Quadrangle.PLSS
  LAYER_42_NAME=Quadrangle.Survey_Lines
  LAYER_43_NAME=Quadrangle.Linear_Drainage_Features
  LAYER_44_NAME=Quadrangle.Contour_Labels
  LAYER_45_NAME=Quadrangle.Contours
  LAYER_46_NAME=Quadrangle.2_5`_Tics
  LAYER_47_NAME=Quadrangle.2_5`_Tics.Interior_Grid_Intersections
  LAYER_48_NAME=Quadrangle.2_5`_Tics.Grid_Tics_along_Neatline
  LAYER_49_NAME=Quadrangle.UTM_Grid
  LAYER_50_NAME=Quadrangle.UTM_Grid.Interior_Grid_Intersections
  LAYER_51_NAME=Quadrangle.UTM_Grid.Grid_Tics_along_Neatline
  LAYER_52_NAME=Quadrangle.UTM_Grid.UTM_Grid_Lines
  LAYER_53_NAME=Quadrangle.Large_Buildings
  LAYER_54_NAME=Quadrangle.Culture_Features
  LAYER_55_NAME=Quadrangle.Landforms
  LAYER_56_NAME=Quadrangle.Drainage_Polygons
  LAYER_57_NAME=Quadrangle.Ownership
  LAYER_58_NAME=Quadrangle.Builtup_Areas
  LAYER_59_NAME=Quadrangle.WoodlandUSGS_P
1: Quadrangle_Culture_Features
2: Quadrangle_Contour_Labels
3: Quadrangle_Contours
4: Quadrangle_2_5`_Tics_Interior_Grid_Intersections
5: Quadrangle_2_5`_Tics_Grid_Tics_along_Neatline
6: Quadrangle_UTM_Grid_Interior_Grid_Intersections
7: Quadrangle_UTM_Grid_Grid_Tics_along_Neatline
8: Quadrangle_UTM_Grid_UTM_Grid_Lines
9: Quadrangle_Large_Buildings
10: Quadrangle_Drainage_Polygons
11: Quadrangle_Ownership
12: Quadrangle_Builtup_Areas
13: Quadrangle_WoodlandUSGS_P
Thank you,
Max
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180629/d7fb6e89/attachment-0001.html>
