[gdal-dev] Troubleshooting palette management. Potential bug in palette for overviews?
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Thu Mar 8 06:32:09 PST 2018
Hi Even,
I'm resurrecting this old post since I think we have (GeoServer) been hit
by that problem again (although I'm not 100% sure about that).
http://osgeo-org.1560.x6.nabble.com/Geotiff-pyramids-non-transparant-while-original-is-transparent-td5357343.html
Do you know if there is any plan to fix https://trac.osgeo.org/gdal/
ticket/2213?
Best Regards,
Daniele
On Fri, Nov 25, 2016 at 12:14 PM, Daniele Romagnoli <
daniele.romagnoli at geo-solutions.it> wrote:
> JAI-ImageIO TIFFDecompressor does the same (Line 0888):
> https://java.net/projects/jai-imageio-core/sources/svn/
> content/trunk/src/share/classes/com/sun/media/imageio/
> plugins/tiff/TIFFDecompressor.java?rev=254
> (also putting an imageio-ext link for quicker reference)
> https://github.com/geosolutions-it/imageio-ext/
> blob/master/plugin/tiff/src/main/java/it/geosolutions/
> imageio/plugins/tiff/TIFFDecompressor.java#L900
> Note the:
> redLut[i] = (byte)((colorMap[i]*255)/65535);
> which results into using a 257 scale factor.
> Cheers,
> Daniele
> On Fri, Nov 25, 2016 at 11:27 AM, Ari Jolma <ari.jolma at gmail.com> wrote:
>> 24.11.2016, 18:01, Even Rouault kirjoitti:
>> Could be worth fixing that if that cause issues (apparently in your use
>> case at least), but I'd be interested by information of what is the
>> standard/recommanded/best-practice-in-the-industry/etc... formulas to
>> use for the mapping between the [0,255] and [0,65535] ranges.
>> At least in the GTK circles it seems to be a standard practice to use the
>> 257 as the scaling factor. See for example
>> http://gtk2-perl.sourceforge.net/doc/pod/Gtk2/Gdk/Color.html
>> Ari
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Daniele Romagnoli
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax: +39 0584 1660272 <+39%200584%20166%200272>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
Regards,
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
GeoSolutions S.A.S.
Italy
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180308/4149896a/attachment-0001.html>
