[gdal-dev] limiting drivers that get registered
Kurt Schwehr
schwehr at gmail.com
Thu Mar 8 10:57:11 PST 2018
I use bazel for building, so the build info isn't useful. You'll have to
hack the makefiles a bit.
I also tried to stop things from registering...
find . -name \*.cpp | egrep -v
'autotest|swig|apps|fuzzers|gdaldrivermanager.cpp|ogrregisterall.cpp|gdalallregister.cpp'
| xargs egrep 'Register[(][)];|OGRRegisterAll|GDALRegister' | egrep -v
'void|: +[*]|:/'
Here are my two diffs: (note that I don't define FRMT_raw in my builds)
diff -u a/gdalallregister.cpp b/gdalallregister.cpp
--- a/gdalallregister.cpp 2018-03-08 10:40:24.342388944 -0800
+++ b/gdalallregister.cpp 2017-12-28 10:13:13.000000000 -0800
@@ -67,7 +67,8 @@
#ifdef FRMT_vrt
GDALRegister_VRT();
- GDALRegister_Derived();
+ // GDALRegister_Derived();
#endif
#ifdef FRMT_gtiff
@@ -220,7 +221,8 @@
#endif
#ifdef FRMT_netcdf
- GDALRegister_GMT();
+ // GDALRegister_GMT();
GDALRegister_netCDF();
#endif
@@ -406,6 +408,11 @@
/* ASCII-header in the same directory. */
+ GDALRegister_EHdr();
+ GDALRegister_ENVI();
#ifdef FRMT_raw
GDALRegister_PNM();
GDALRegister_DOQ1();
@@ -476,7 +483,8 @@
#endif
#ifdef FRMT_hdf5
- GDALRegister_BAG();
+ // GDALRegister_BAG();
GDALRegister_HDF5();
GDALRegister_HDF5Image();
#endif
diff -u a/ogrregisterall.cpp b/ogrregisterall.cpp
--- a/ogrregisterall.cpp 2018-03-08 10:54:56.775492742 -0800
+++ b/ogrregisterall.cpp 2018-03-08 10:54:27.643856370 -0800
@@ -106,7 +106,7 @@
RegisterOGRGMT();
#endif
#ifdef SQLITE_ENABLED
- RegisterOGRGeoPackage();
+ // RegisterOGRGeoPackage();
RegisterOGRSQLite();
#endif
#ifdef DODS_ENABLED
On Thu, Mar 8, 2018 at 9:21 AM, Tobias Wendorff <
tobias.wendorff at tu-dortmund.de> wrote:
> Am Do, 8.03.2018, 17:47 schrieb Kurt Schwehr:
> > I get a little more aggressive compared to what others suggested by
> > commenting out register calls in gdalallregister.cpp and
> > ogrregisterall.cpp
> > and removing the code for the drivers.
> Share, share, share :)
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180308/e1d0f644/attachment-0001.html>
