[gdal-dev] Revisiting ecw
Even Rouault even.rouault at spatialys.com
Tue Mar 13 13:24:35 PDT 2018
Hexagon released ECW SDK 5.4 [1] with support for the CXX11 ABI, which
makes it compatible with gcc >= 5.1 with its default ABI.
I've just added support in configure in trunk and 2.2 branch to detect if we
must link against the libNCSEcw with the newabi or the one with the oldabi
Note: I've found that if you also link against the Teigha libraries, the ECW driver
tends to crash. The joy of combining two proprietary closed-source SDKs...
Even
[1] https://download.hexagongeospatial.com/downloads/ecw/erdas-ecw-jp2-sdk-v5-4-linux
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180313/7b2be167/attachment.html>
