[gdal-dev] Revisiting ecw
Even Rouault
even.rouault at spatialys.com
Fri Mar 16 07:43:53 PDT 2018
> Note: I've found that if you also link against the Teigha libraries, the ECW
> driver tends to crash. The joy of combining two proprietary closed-source
> SDKs...
Regarding the above finding, I've found that both ECW SDK and Teigha SDK
embeds a copy of TinyXML, probably at a different version / ABI, which
explains those runtime crashes. Hexagon developers have been made aware of
that issue.
Even
http://www.spatialys.com
