[gdal-dev] GeoPDF with a KML layer and a rotated GeoTIFF layer
Andreas Oxenstierna ao at t-kartor.se
Tue Mar 20 01:38:58 PDT 2018
Have you tested to include the OGR datasource in a VRT file instead,
with the LayerSRS tag defined?
> Oups sorry for my uncomplete message : "raw" tags are not well handled.
> Below is the GDAL command I used to create my GeoPDF image:
> gdal_translate.exe -of PDF --config LIBKML_RESOLVE_STYLE YES \
> 		   -co OGR_DATASOURCE=rectangle.kml \
> 		   -co LAYER_NAME=lena lena_rot.tif \
> 		   lena_rot.tif.pdf
> Below, the next command to convert the GeoPDF image back to GeoTIFF :
> gdal_translate -of GTiff lena_rot.tif.pdf lena_rot.tif.pdf.tif
> Philippe
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Hälsningar
Andreas Oxenstierna
T-Kartor Geospatial AB
mobile: +46 733 206831
mailto: ao at t-kartor.se
http://www.t-kartor.com
