[gdal-dev] https://github.com/OSGeo/gdal is the current SCM and ticketing system
Kyle Shannon kyle at pobox.com
Mon Mar 26 08:38:54 PDT 2018
Even,
On Fri, Mar 23, 2018 at 8:09 AM, Even Rouault
<even.rouault at spatialys.com> wrote:
> OK, so now you can and should use https://github.com/OSGeo/gdal to track
> developement and file new tickets/issues
> Trac ticket creation has been disabled. You can still modify existing tickets.
> One side effect of pushing the rewritten commit messages is that all still
> opened pull requests (~20) in the previous mirror have been forced closed (not
> surprising since the sha1sum of the base commits have been modified). So if
> you had pending work, please rebase it on top of the current
> https://github.com/OSGeo/gdal and issue a new pull request. Forks of the
> previous https://github.com/OSGeo/gdal will probably have to be recreated from
> scratch, or "rebased" to the current one as well.
> The cron job that triggers website refresh has now been updated.
> GDAL SVN committers that don't have yet push rights to github, please submit a
> pull request to gdal/COMMITTERS file with a new line with your contact
> information, so your github nickname can be added to the authorized list of
> people with push rights (if you already have push rights, please also update
> COMMITTERS with your info)
> I've updated a few things on Trac wiki to point to github. If you still see
> references to svn or Trac for new tickets, you're welcome to fix them.
> I've initiated
> https://github.com/OSGeo/gdal/blob/master/CONTRIBUTING.md
> Needs more love.
> Kyle, you'll likely need to update your job for Coverity Scan.
I'll work on enabling the webhook enabled scan and drop the cron job
on my machine when that is up.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Kyle
