[gdal-dev] Adding WRITE_ID creation option for GeoJSON
Even Rouault even.rouault at spatialys.com
Mon Mar 26 10:22:55 PDT 2018
On vendredi 23 mars 2018 10:59:02 CEST Rahkonen Jukka (MML) wrote:
> Hi,
> Am I right that there is no option to force the writing of "id" member to
> GeoJSON features? I have noticed that if I run ogr2ogr with -preserve_fid
> option then the "id" member is added { "type": "Feature", "id": 0,
> "properties":
> However, if I don't use -preserve_fid I have not discovered any way to get
> "id" into GeoJSON. If I am right, would it make sense to add the WRITE_ID
> option like the existing WRITE_NAME http://www.gdal.org/drv_geojson.html?
ID_FIELD and ID_TYPE layer creation options added per
https://github.com/OSGeo/gdal/commit/812a6eea6ef36462531bfa98ff74ca21b361d1b7
Even
http://www.spatialys.com
