[gdal-dev] limiting drivers that get registered
Even Rouault
even.rouault at spatialys.com
Tue Mar 27 03:49:34 PDT 2018
On mardi 27 mars 2018 21:09:41 CEST Ben Elliston wrote:
> Hi Even
> On 08/03/18 23:34, Even Rouault wrote:
> > If you use GDAL as a library from your own code (C/C++), you can also
> > directly call the GDALRegister_XXXX() / OGRRegisterXXXX() functions you
> > are interested in, instead of GDALAllRegister()
> This is ideal, as it allows a handful of drivers to be registered first,
> and then GDALAllRegister() to be called to register everything else down
> the line
Hum why would you need to call GDALAllRegister() if you already manually
registered some of them ?
> . Unfortunately, it is impossible to know which drivers are
> present until you call an undefined function in the GDAL shared library.
> For example, GDALRegister_HDF4() is not defined if the HDF4 library
> isn't found at configure time.
> Is there any way to know which drivers are available at runtime?
Well, call GDALAllRegister() and then query GDALGetDriverByName(driver_name).
You can unregister a driver with GDALDeregisterDriver()
Even
http://www.spatialys.com
