[gdal-dev] GDAL with Teigha DWG driver
Ivan Lucena lucena_ivan at hotmail.com
Tue Mar 27 13:24:50 PDT 2018
Hi Nicol,
I've been through the same problem.
Actually, I was helping someone that had that problem.
If I remember correctly, the SDK that you download from the site doesn't have some needed components to build the GDAL driver.
You would need to register ($?) with that company to get the full SDK.
The guys that I was helping did that and it worked fine for them.
But don't we have a new driver to handle that format now that is based on open source?
Regards,
Ivan
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Nicol Hermann <gdal at geoworld.de>
Sent: Tuesday, March 27, 2018 3:45 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] GDAL with Teigha DWG driver
Hello List,
I am trying to compile GDAL 2.2.4 with TeighaFileConverter_4.3.2.0 (htt
ps://www.opendesign.com/guestfiles/teigha_file_converter).
The configure parameters are:
--with-teigha=/usr/bin/TeighaFileConverter_4.3.2.0 --with-teigha-
plt=Linux
Unfortunately the make command fails with:
In file included from ogr_dwg.h:41:0,
                 from ogrdwgdriver.cpp:29:
dwg_headers.h:38:23: fatal error: OdaCommon.h: No such file or
directory
compilation terminated.
Does anybody know where to get 'OdaCommon.h' from?
Anything else to change?
Thanks
Nicol
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180327/c5da29b2/attachment-0001.html>
