[gdal-dev] mssql append fails for non-geometry layers
Martin Landa landa.martin at gmail.com
Thu May 3 10:31:44 PDT 2018
Hi all,
let's assume sample data:
$ ogrinfo sample.gpkg
1: SOBR (Point)
2: VLA (None)
Append for geometry layers seems to work:
1) ogr2ogr -f MSSQLSpatial MSSQL:database=kn sample.gpkg sobr
1> select count(*) from sobr
2> go
       5437
2) ogr2ogr -f MSSQLSpatial -append MSSQL:database=kn sample.gpkg sobr
2> go
      10874
The same procedure fails for non-geometry layers:
1) ogr2ogr -f MSSQLSpatial MSSQL:database=kn sample.gpkg vla
1> select count(*) from vla
2> go
        111
2) ogr2ogr -f MSSQLSpatial -append MSSQL:database=kn sample.gpkg vla
ERROR 1: Error creating layer: [Microsoft][SQL Server Native Client 11.0][SQL Se
rver]There is already an object named 'vla' in the database. When using the over
write option and the layer doesn't contain geometry column, you might require to
 use the MSSQLSPATIAL_LIST_ALL_TABLES config option to get the previous layer de
leted before creating the new one.
ERROR 1: Terminating translation prematurely after failed
translation of layer VLA (use -skipfailures to skip errors)
OK, let's try with MSSQLSPATIAL_LIST_ALL_TABLES
3) ogr2ogr -f MSSQLSpatial -append --config
MSSQLSPATIAL_LIST_ALL_TABLES YES MSSQL:database=kn sample.gpkg vla
Same error:
Number of records unchanged:
2> go
        111
It seems to me as a bug, or is there anything I miss? Thanks for
pointers, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
