[gdal-dev] deb package for 2.2.3
Angelos Tzotsos
gcpp.kalxas at gmail.com
Fri May 4 01:06:04 PDT 2018
I am planning to update UbuntuGIS with the new GDAL 2.3.0 release once
it is out.
Let me check if I can push 2.2.3 to experimental within the weekend.
Cheers,
Angelos
On 05/04/2018 08:39 AM, Grégory Bataille wrote:
> wow, ok, a bit more work than I expected. Now I understand why it's hard to
> keep it up-to-date.
> Thanks for the osgeolive pointer, did not know about it.
> Cool if you move soon to 2.3.0 and therefore feeds ubuntugis. I'll still
> see if I can quickly get somewhere is the meantime on my own with what you
> sent
> cheers
> Gregory Bataille
> On Fri, May 4, 2018 at 7:28 AM Sebastiaan Couwenberg <sebastic at xs4all.nl>
> wrote:
>> On 05/04/2018 07:11 AM, Grégory Bataille wrote:
>>> I'm running gdal 2.2.2 from ubuntu-gis/experimental .deb package and I
>> just
>>> got stuck by https://trac.osgeo.org/gdal/ticket/7143.
>>> Took me some time to debug because I develop locally on Mac, where the
>>> package is at 2.2.3 and the bug is fixed.
>>> What does it take to build the .deb package. Is this something that
>> someone
>>> can do? is this something sufficiently scripted that I can do it and give
>>> you guys the result for publication?
>> In the case of UbuntuGIS, you can rebuild the source package from
>> Debian. The sources are available in git:
>> https://salsa.debian.org/debian-gis-team/gdal
>> https://salsa.debian.org/debian-gis-team/gdal-grass
>> Once you have rebuild the gdal package, you need to rebuild all reverse
>> dependencies (packages that depend on libgdal20) with the new gdal to
>> have them use the new virtual ABI dependency.
>> Because of interdependencies you need to rebuild the packages in the
>> correct order, have a look at:
>> https://trac.osgeo.org/ubuntugis/wiki/BuildOrder
>> Note that this page may have become outdated again. The Debian GIS
>> transition trackers shows all libgdal20 reverse dependencies in Debian
>> unstable:
>> https://linuxminded.nl/debian/gis-transitions/html/gdal.html
>> You will need to host all the rebuild packages in your own PPA to easily
>> install them. If your goal is to update the gdal packages in the
>> UbuntuGIS PPA, you need to coordinate your contributions on the
>> appropriate mailinglist:
>> https://lists.osgeo.org/mailman/listinfo/ubuntu
>> Due to the lack of manpower, pretty much all the packages in the
>> UbuntuGIS PPA get copied from the OSGeoLive PPA where a little more
>> manpower is available to create backports of Debian GIS packages for
>> Ubuntu LTS releases.
>> The next OSGeoLive release will be based on bionic, and will rely for a
>> large part on the packages already available in Ubuntu because they're
>> up-to-date with the latest upstream releases. At least proj & gdal will
>> most likely be updated to 5.0.1 & 2.3.0 for OSGeoLive 12.0. So you can
>> also just wait for those packages to find their way from the OSGeoLive
>> PPA to the UbuntuGIS PPA. Contributing to OSGeoLive is also most welcome.
>> Kind Regards,
>> Bas
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180504/b53050db/attachment.html>
