[gdal-dev] GDAL 2.3.0 RC1 available
Even Rouault
even.rouault at spatialys.com
Fri May 4 09:25:56 PDT 2018
I've issued a release candidate for GDAL 2.3.0
The source is available at:
http://download.osgeo.org/gdal/2.3.0/gdal-2.3.0RC1.tar.xz
http://download.osgeo.org/gdal/2.3.0/gdal-2.3.0RC1.tar.gz
http://download.osgeo.org/gdal/2.3.0/gdal230RC1.zip
A snapshot of the Python autotest suite can be downloaded from:
http://download.osgeo.org/gdal/2.3.0/gdalautotest-2.3.0RC1.tar.gz
http://download.osgeo.org/gdal/2.3.0/gdalautotest-2.3.0RC1.zip
The GDAL-GRASS plugin hasn't changed since beta1 :
http://download.osgeo.org/gdal/2.3.0/gdal-grass-2.3.0.tar.gz
Snapshot of the documentation :
http://download.osgeo.org/gdal/2.3.0/gdal230doc.zip
The NEWS page has been updated:
https://trac.osgeo.org/gdal/wiki/Release/2.3.0-News
I'll call for a vote to promote it to final middle of next week if nothing serious is reported before.
Changes since beta1 :
2a1f817 jp2kak.py: adjust expected checksums for Kakadu 7.10.4
2487aa3 ogrinfo/ogr2ogr with -sql @filename: remove lines starting with '-- ' (relates to/fixes #459)
1d9b16d ogr_sql_rfc28.py: fix memleak
961b551 DXF: avoid very long processing time. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=7854. Credit to OSS Fuzz
9acbe8a Geoconcept: avoid infinite loop. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=7851. Credit to OSS Fuzz
59e5ede ODS: avoid adding too many columns to too many existing feataures. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=7868. Credit to OSS Fuzz
e711462 XLSX: avoid timeout. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=7784. Credit to OSS Fuzz
18203f8 MITAB: improve performance when reading huge number of fields from .mif. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=7825. Credit to OSS Fuzz
805999a RDA: change extension to .dgrda to differentiate from R data (#470)
ae9da1a Re-install gdal_csv.h
62dd0e1 E00GRID: better detect short file situation to avoid very long processing time. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=7781. Credit to OSS Fuzz
f8efbf8 ISCE: avoid potential int overflow. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=7948. Credit to OSS Fuzz
56578e7 VRTDataset::AddBand(): honour 'PixelFunctionLanguage' option (fixes #501)
4f9733e generate_gdal_version_h.sh: avoid regenerating gdal_version.h on a non-dev version (fixes build failures on Travis-CI with 2.3.0beta1)
bafa089 SNODAS: accept header lines up to 1024 characters. Fixes #506
dce1060 WCS: do not crash if the CoverageInfo has a EnvelopeWithTimePeriod
bff1e5c XLSX: avoid crash when I/O error occurs on saving. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8031. Credit to OSS Fuzz
acb0049 ogrmerge.py: use ogr.wkbUnknown
a3af874 OpenJPEG: allow YCC for non-Byte datasets; and allow 4-band MCT with openjpeg >= 2.2
14c0333 GTiff: avoid potential unwanted network access. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8045. Credit to OSS Fuzz
167eb92 IRIS: avoid infinite loop. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8049. Credit to OSS Fuzz
7cd9a6f m4/acinclude.m4: replace use of CCFLAGS by plain CFLAGS (fixes #529)
3ea0bbd m4/acinclude.m4: require 'long long' type (fixes #530)
83369b4 cpl_port.h: error out if HAVE_LONG_LONG not defined, and remove some code testing CPL_HAS_GINT64 (refs #530)
3e78f98 Add assertion to avoid gcc -Wnull-dereference to have a false positive
bf6dc2a gdalwarp: proper progress bar for warp to VRT
dfac928 implement CPLReadLine3L() (#479)
e366465 New issues with VFK parser logic, see #365
da2feb2 VFK: modify VFKReader::ReadLine() to use CPLReadLine3L, see #365
f7b90fa CPLReadLine3L since 2.3.0, see #479
080ffc4 configure: fix long long detection with CFLAGS=-Wall (refs #530)
58c0c6a IRIS: avoid infinite loop. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8058. Credit to OSS Fuzz
98f6a4a GPKG: fix overview creation with big overview factors on some datasets
f4a3c2f AVCE00: avoid performance issue with retrieving the SRS and big number of layers. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8065. Credit to OSS Fuzz
b861528 DXF: avoid performance issue when reading INSERT. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8067. Credit to OSS Fuzz
c110ff1 CTG: fix int overfow. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8081. Credit to OSS Fuzz
8e4c736 ogr2ogr: fix compilation error with Crypto++ 7.0.0 (fix #541) (#547)
b30e9d3 EHdr: avoid int overflow. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8110. Credit to OSS Fuzz
94030a7 Overview creation: avoid creating too many levels, and fix related heap buffer overflow (fixes #557) (#561)
10f3127 Improvements to WCS driver (#521) (fixes #515, fixes #516)
21c7e5e SetStatistics(): write a STATISTICS_APPROXIMATE=YES metadata item if bApproxOK=true, and take it into account in GetStatistics() (fixes https://trac.osgeo.org/gdal/ticket/4857, https://trac.osgeo.org/gdal/ticket/4576). Update EHdr driver to only write .stx if bApproxOK=false (fixes #514)
900120a RIK: fix read stack buffer overflow. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8117. Credit to OSS Fuzz
949e46b PCIDSK: fix heap-read-buffer overflow. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8121. Credit to OSS Fuzz
63cd4fb XLSX: avoid adding too many columns to too many existing feataures. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8122. Credit to OSS Fuzz
3746b12 DXF: avoid very long processing time on corrupted files. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8123. Credit to OSS Fuzz
65afca4 GDALRasterBand::ComputeStatistics(): remove dead-code added recently, and better testing
80814c6 ISO8211: avoid timeout when opening a huge archive as a directory. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8128. Credit to OSS Fuzz
a72f4e4 DXF: fix memleak in error code path. Fixes https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8134. Credit to OSS Fuzz
33c893f RIK: actually fix https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=8117
55eaf7f OGR_PDS: fix reading 8-byte IEEE_REAL fields (fixes #570)
b763225 MITAB: export BRUSH(fc:#.....) with mapinfo brush 2 (solid fill)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180504/0fd8fea9/attachment-0001.html>
