[gdal-dev] connect mssql from linux
Mateusz Loskot
mateusz at loskot.net
Tue May 8 13:29:43 PDT 2018
AFAIK, yes the new driver does support the extension API (I think the
driver installer let's you to install SDK for it).
The bcp utility that uses the driver is available on Linux.
Mateusz Loskot, mateusz at loskot.net
(Sent from mobile)
On Tue, 8 May 2018, 22:10 Jeremy Palmer, <palmerjnz at gmail.com> wrote:
> But does the ODBC driver support the BCP (bulk copy) API? That was the
> original reason to use the native client.
> On Wed, May 9, 2018 at 8:06 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
>> FYI, the SQL Server Native Client is not the best choice to connect to
>> the latest MSSQL.
>> You may want to to switch to the new driver available for both, Linux and
>> Windows
>> https://docs.microsoft.com/en-us/sql/connect/odbc/linux-mac/installing-the-microsoft-odbc-driver-for-sql-server
>> (Sent from mobile)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180508/64667764/attachment.html>
