[gdal-dev] Example about how to save Tiled Gridded Coverage	Data into GeoPackage
    Even Rouault
    even.rouault at spatialys.com
    Tue May 15 06:04:43 PDT 2018
> Thanks, works well with 32 bit floating point tiffs as source and the gpkg
> DEM opens fine with QGIS 3. I know I can add several DEM tiffs by combining
> them into one datasource with VRT but is there any way to add data into an
> existing raster table? I understand that a general solution would be tricky
> because new data might require to increase the tile matrix, and within the
> existing matrix a well working system should be able to combine and merge
> partial tiles. But is it possible to add data into raster table at all, for
> example by inserting and overwriting tiles in Web Mercator grid?
Jukka,
Extending the limits of an existing tile matrix would require some work (renumbering the
existing tiles, recomputing overviews, etc...)
But if you use a global tiling system like Web Mercator, you can do it, but it is admitedly a bit
tricky.
gdalwarp new_data.tif existing.gpkg \
	-doo MINX=... -doo MINY=... -doo MAXX=... -doo MAXY=....
While in theory you could use the exterme value of the Web Mercator projection (+/-
20037508.34) for those minx, etc values, this would take hours/days to process given how
gdalwarp works.
So you will have to compute a more restricted bounding box from the existing data in the
raster table and the new data you want to add.
And finally you need to adjust the gpkg_contents min_x, min_y, max_x and max_y bounds to
the new bounding box with something like
ogrinfo existing.gpkg -sql "UPDATE gpkg_contents WHERE table_name = 'foo' SET min_x = ...,
min_y = ..., max_x = ...., max_y = ...."
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180515/a4fe956a/attachment.html>
