[gdal-dev] How to estimate the width/height size of output image in a target CRS without running gdalwarp?
Bang Pham Huu b.phamhuu at jacobs-university.de
Thu May 17 23:38:01 PDT 2018
Thanks Even, your suggestion works, I found an example here for Python
that could help others with this powerful feature:
https://gis.stackexchange.com/a/140053/17733
On 05/17/2018 09:02 PM, Even Rouault wrote:
> On jeudi 17 mai 2018 11:33:40 CEST Bang Pham Huu wrote:
> > Hi,
> > I have a hard problem to find the width/height of a 2D GeoTiff file
> > which is reprojected from a source CRS (e.g: EPSG:4326) to target CRS
> > (e.g: EPSG:3857) without running gdalwarp. Because, the file could be
> > large (GBs) and I don't need the projected output file, just need the
> > width/height of it.
> > What could be done with gdalwarp is:
> > gdalwarp  -s_srs EPSG:4326 -t_srs EPSG:3857 full.tif full_3857.tif
> > gdalinfo full_3857.tif
> > Size is 879, 811 (width/height).
> > I've searched a lot and what seems to be good without doing the real
> > projection is this gdal function: GDALSuggestedWarpOutput2
> https://github.com/OSGeo/gdal/blob/106c8288e7a05f4efc1a588c5a3b2da7ec52d915/
> > gdal/alg/gdaltransformer.cpp#L354. However, it doesn't help because my
> > application developed in Java and it uses gdal-java (GDAL JNI)
> https://search.maven.org/#artifactdetails%7Corg.gdal%7Cgdal%7C1.11.1%7Cpom
> > as library. Unfortunately, I cannot find this GDALSuggestedWarpOutput2()
> > from gdal-java http://gdal.org/java/overview-summary.html then cannot
> > invoke this C++ function from my application to test.
> > Can anyone please give me a hint to solve this problem?
> Hi,
> You can use gdal.AutoCreateWarpedVRT() which will create a in-memory
> warped
> VRT without doing the actual warping.
> http://gdal.org/java/org/gdal/gdal/gdal.html#AutoCreateWarpedVRT-org.gdal.gdal.Dataset-
> and query the dimensions of the returned Dataset
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180518/c93cacb4/attachment-0001.html>
