[gdal-dev] Problems with pct2rgb and gdal_translate
Even Rouault
even.rouault at spatialys.com
Tue May 29 01:44:42 PDT 2018
On mardi 29 mai 2018 00:09:42 CEST Aklim wrote:
> Hello.
> I try to mosaic images using gdalwrap from following instructions here
> https://download.osgeo.org/gdal/workshop/foss4ge2015/workshop_gdal.html#__Re
> fHeading__5961_1333016408
> <https://download.osgeo.org/gdal/workshop/foss4ge2015/workshop_gdal.html#__
> RefHeading__5961_1333016408>
> 1. problem with pct2rgb
> Traceback (most recent call last):
> File "C:\OSGEO4~1\bin\pct2rgb.py", line 121, in <module>
> ct_size = ct.GetCount()
> AttributeError: 'NoneType' object has no attribute 'GetCount'
That means your input raster has no color table. You don't need to do that
preliminary step.
The tutorial works out-of-the-box only with the input data it was written.
Even
http://www.spatialys.com
