[gdal-dev] Alternative to GPKG format
koji higuchi
koji51guchi at gmail.com
Thu Nov 1 03:02:56 PDT 2018
Hi, my source file is too big, around 19gb (europe-latest.osm.pbf)
I also tried ogr2ogr for clipping into region as follows.
ogr2ogr -f, gpkg, -clipdst, str(ulx), str(lry), str(lrx), str(uly), fo, fi
but it was also very slow.
On Thu, Nov 1, 2018 at 6:55 PM jratike80 <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> koji higuchi wrote
> > Hi, following is the code I used:
> > Import os, osmium, fiona
> > fi = 'europe-latest.osm.pbf'
> > fo = 'europe-latest.dpkg'
> > drv = 'DPKG'
> Hi,
> I am not able to evaluate if your code is effective or not. However, I can
> give you some numbers for comparison.
> Test data http://download.geofabrik.de/europe/finland-latest.osm.pbf
> - 322 MB as .pbf
> - 770725 points
> - 1778917 lines
> - 3128 multilinestrings
> - 2087911 multipolygons
> - 6985 other relations
> Command:
> ogr2ogr -f gpkg finland.gpkg finland-latest.osm.pbf
> Execution time on Windows laptop:
> 2 minutes and 20 seconds
> If you experience some slower performance it is probably not because of
> SQLite/GeoPackage as a format is slow but because something is not done in
> a
> way that is not optimal for the format. Could you also define your source
> data and the performance that you have measured?
> -Jukka Rahkonen-
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181101/30200ad3/attachment-0001.html>
