[gdal-dev] Alternative to GPKG format
koji higuchi koji51guchi at gmail.com
Thu Nov 1 03:05:57 PDT 2018
Hi Even
I am trying to replace using fiona by pure ogr.
but having difficult to collapse the code with class and objects.
If i could extract geom and tags in a ogr pythonic way, then it be better
On Thu, Nov 1, 2018 at 6:45 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> You are perhaps using a too old version of Fiona. Recent versions insert
> features within OGR transactions. Should be fine with latest Fiona 1.8.0
> See https://github.com/Toblerity/Fiona/issues/476
> > Hi, following is the code I used:
> > Import os, osmium, fiona
> > fi = 'europe-latest.osm.pbf'
> > fo = 'europe-latest.dpkg'
> > drv = 'DPKG'
> > crs = {'no_defs': True, 'ellps': 'WGS84', 'datum': 'WGS84', 'proj':
> > 'longlat'}
> >  schema = {'geometry': 'LineString',
> >                    'properties': {'id': 'float', 'name' : 'str', 'kind' :
> > 'str'}}
> > outfile = fiona.open(fo, 'w', driver=drv, crs=crs, schema=schema)
> > geomfab = osmium.geom.GeoJSONFactory()
> > class ShapeConverter(osmium.SimpleHandler):
> >       def way(self, w):
> >            if 'place' in w.tags:
> >                rec = {'geometry' : eval(geomfab.create_linestring(w)),
> >                       'properties' : {'id' : float(w.id),
> >                                      'name' : w.tags.get('name'),
> >                                        'kind' : w.tags['place']}}
> >                outfile.write(rec)
> > ShapeConverter().apply_file(fi, locations=True)
> > On Thu, Nov 1, 2018 at 4:10 PM jratike80 <
> > jukka.rahkonen at maanmittauslaitos.fi> wrote:
> > > koji higuchi wrote
> > > > Hi
> > > > I am extracting .osm.pbf file into .gpkg; but the writing rate is
> very
> > > > slow.
> > > > When I write into .shp, rate is faster but its limit is 4gb.
> > > > So, what other format is better for larger than 4gb requirement?
> > > > Thanks for your ideas.
> > > > Koji
> > > Hi,
> > > Show the exact command that you are using so we can see if it could be
> > > made
> > > faster. For example if you happen to use -skipfailures for handling the
> > > invalid geometries of the OSM data then you will make GDAL to do a new
> > > transaction for each row and that certainly is slow. But let's have a
> look
> > > at your command first.
> > > -Jukka Rahkonen-
> > > Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181101/2a24ab69/attachment.html>
