[gdal-dev] How to Use Gdal in Microsoft Visual Studio C++
bradh at frogmouth.net bradh at frogmouth.net
Thu Nov 1 03:50:29 PDT 2018
The problem below is nothing to do with GDAL, you just need to initialise the variable (probably by some kind of command line argument - argv[1] if nothing else). If that doesn't make sense, is there another programming language that you are more comfortable with?
Brad
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Athin
Sent: Thursday, 1 November 2018 8:32 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] How to Use Gdal in Microsoft Visual Studio C++
Hai All,
My target just know want to try to display raster map, but i still stuck in this starting point. The code I run below will display an error
error c4700 uninitialized local variable 'pszFilename' used
can someone help me regarding this and what i need to with the file i download from this link:https://trac.osgeo.org/gdal/wiki/DownloadSource
where i need to add on VS2012?
Thank you and best regards
#include "gdal_priv.h"
#include "cpl_conv.h" // for CPLMalloc() #include "stdafx.h"
#include "gdal.h"
int main()
	class GDALDataset;
	const char *pszFilename;
    GDALDataset *poDataset;
	void CPL_DLL CPL_STDCALL GDALAllRegister(void);
    poDataset = (GDALDataset *) GDALOpen(pszFilename, GA_ReadOnly );
    if( poDataset == NULL )
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
