[gdal-dev] Alternative to GPKG format
Andreas Neumann
a.neumann at carto.net
Thu Nov 1 04:27:23 PDT 2018
Just a quick stupid question: are you writing to a local file system or
to a network filesystem. The latter can be substantially slower than the
former, esp. with Geopackage.
Andreas
Am 01.11.18 um 12:10 schrieb koji higuchi:
> Hi Even
> I managed to write gpkg without ogr without fiona using class
> ShapeConverter(osmium.SimpleHandler).
> still, speed seems slow.
> Any idea to increase it up.
> On Thu, Nov 1, 2018 at 7:05 PM koji higuchi <koji51guchi at gmail.com
> <mailto:koji51guchi at gmail.com>> wrote:
> Hi Even
> I am trying to replace using fiona by pure ogr.
> but having difficult to collapse the code with class and objects.
> If i could extract geom and tags in a ogr pythonic way, then it be
> better
> On Thu, Nov 1, 2018 at 6:45 PM Even Rouault
> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>>
> wrote:
> You are perhaps using a too old version of Fiona. Recent
> versions insert
> features within OGR transactions. Should be fine with latest
> Fiona 1.8.0
> See https://github.com/Toblerity/Fiona/issues/476
> > Hi, following is the code I used:
> > Import os, osmium, fiona
> > fi = 'europe-latest.osm.pbf'
> > fo = 'europe-latest.dpkg'
> > drv = 'DPKG'
> > crs = {'no_defs': True, 'ellps': 'WGS84', 'datum': 'WGS84',
> 'proj':
> > 'longlat'}
> > schema = {'geometry': 'LineString',
> > 'properties': {'id': 'float', 'name' :
> 'str', 'kind' :
> > 'str'}}
> > outfile = fiona.open(fo, 'w', driver=drv, crs=crs,
> schema=schema)
> > geomfab = osmium.geom.GeoJSONFactory()
> > class ShapeConverter(osmium.SimpleHandler):
> > def way(self, w):
> > if 'place' in w.tags:
> > rec = {'geometry' :
> eval(geomfab.create_linestring(w)),
> > 'properties' : {'id' : float(w.id
> <http://w.id>),
> > 'name' :
> w.tags.get('name'),
> > 'kind' :
> w.tags['place']}}
> > outfile.write(rec)
> > ShapeConverter().apply_file(fi, locations=True)
> > On Thu, Nov 1, 2018 at 4:10 PM jratike80 <
> > jukka.rahkonen at maanmittauslaitos.fi
> <mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
> > > koji higuchi wrote
> > > > Hi
> > > > I am extracting .osm.pbf file into .gpkg; but the
> writing rate is very
> > > > slow.
> > > > When I write into .shp, rate is faster but its limit is 4gb.
> > > > So, what other format is better for larger than 4gb
> requirement?
> > > > Thanks for your ideas.
> > > > Koji
> > > Hi,
> > > Show the exact command that you are using so we can see if
> it could be
> > > made
> > > faster. For example if you happen to use -skipfailures for
> handling the
> > > invalid geometries of the OSM data then you will make GDAL
> to do a new
> > > transaction for each row and that certainly is slow. But
> let's have a look
> > > at your command first.
> > > -Jukka Rahkonen-
> > > Sent from:
> http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> > > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181101/ea8f8a5b/attachment-0001.html>
