[gdal-dev] Alternative to GPKG format
koji higuchi
koji51guchi at gmail.com
Thu Nov 1 04:40:35 PDT 2018
I'm writing file using class ShapeConverter(osmium.SimpleHandler) and ogr
(not fiona)
But, do not know whether transaction are all written instantaneously and
simultaneously or not...
On Thu, Nov 1, 2018 at 8:34 PM koji higuchi <koji51guchi at gmail.com> wrote:
> Hi Andreas
> I'm writing to a file into my PC disk.
> On Thu, Nov 1, 2018 at 8:32 PM Andreas Neumann <a.neumann at carto.net>
> wrote:
>> Hi,
>> Just a quick stupid question: are you writing to a local file system or
>> to a network filesystem. The latter can be substantially slower than the
>> former, esp. with Geopackage.
>> Andreas
>> Am 01.11.18 um 12:10 schrieb koji higuchi:
>> Hi Even
>> I managed to write gpkg without ogr without fiona using class
>> ShapeConverter(osmium.SimpleHandler).
>> still, speed seems slow.
>> Any idea to increase it up.
>> On Thu, Nov 1, 2018 at 7:05 PM koji higuchi <koji51guchi at gmail.com>
>> wrote:
>>> Hi Even
>>> I am trying to replace using fiona by pure ogr.
>>> but having difficult to collapse the code with class and objects.
>>> If i could extract geom and tags in a ogr pythonic way, then it be better
>>> On Thu, Nov 1, 2018 at 6:45 PM Even Rouault <even.rouault at spatialys.com>
>>> wrote:
>>>> You are perhaps using a too old version of Fiona. Recent versions
>>>> insert
>>>> features within OGR transactions. Should be fine with latest Fiona 1.8.0
>>>> See https://github.com/Toblerity/Fiona/issues/476
>>>> > Hi, following is the code I used:
>>>> > Import os, osmium, fiona
>>>> > fi = 'europe-latest.osm.pbf'
>>>> > fo = 'europe-latest.dpkg'
>>>> > drv = 'DPKG'
>>>> > crs = {'no_defs': True, 'ellps': 'WGS84', 'datum': 'WGS84', 'proj':
>>>> > 'longlat'}
>>>> > schema = {'geometry': 'LineString',
>>>> > 'properties': {'id': 'float', 'name' : 'str',
>>>> 'kind' :
>>>> > 'str'}}
>>>> > outfile = fiona.open(fo, 'w', driver=drv, crs=crs, schema=schema)
>>>> > geomfab = osmium.geom.GeoJSONFactory()
>>>> > class ShapeConverter(osmium.SimpleHandler):
>>>> > def way(self, w):
>>>> > if 'place' in w.tags:
>>>> > rec = {'geometry' : eval(geomfab.create_linestring(w)),
>>>> > 'properties' : {'id' : float(w.id),
>>>> > 'name' : w.tags.get('name'),
>>>> > 'kind' : w.tags['place']}}
>>>> > outfile.write(rec)
>>>> > ShapeConverter().apply_file(fi, locations=True)
>>>> > On Thu, Nov 1, 2018 at 4:10 PM jratike80 <
>>>> > jukka.rahkonen at maanmittauslaitos.fi> wrote:
>>>> > > koji higuchi wrote
>>>> > > > Hi
>>>> > > > I am extracting .osm.pbf file into .gpkg; but the writing rate is
>>>> very
>>>> > > > slow.
>>>> > > > When I write into .shp, rate is faster but its limit is 4gb.
>>>> > > > So, what other format is better for larger than 4gb requirement?
>>>> > > > Thanks for your ideas.
>>>> > > > Koji
>>>> > > Hi,
>>>> > > Show the exact command that you are using so we can see if it could
>>>> be
>>>> > > made
>>>> > > faster. For example if you happen to use -skipfailures for handling
>>>> the
>>>> > > invalid geometries of the OSM data then you will make GDAL to do a
>>>> new
>>>> > > transaction for each row and that certainly is slow. But let's have
>>>> a look
>>>> > > at your command first.
>>>> > > -Jukka Rahkonen-
>>>> > > Sent from:
>>>> http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
>>>> > > _______________________________________________
>>>> > > gdal-dev mailing list
>>>> > > gdal-dev at lists.osgeo.org
>>>> > > https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> Spatialys - Geospatial professional services
>>>> http://www.spatialys.com
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181101/ff15c71e/attachment-0001.html>
