[gdal-dev] The "Bertin 1953" projection
Even Rouault even.rouault at spatialys.com
Tue Nov 6 03:07:18 PST 2018
On mardi 6 novembre 2018 11:53:10 CET Nikos Alexandris wrote:
> Dear list,
> the projection "Bertin 1953" was recently added in Proj4 [0]
> [0] https://github.com/OSGeo/proj.4/blob/master/src/PJ_bertin1953.c
> What would be the fastest way to try this out, except of compiling all
> Proj4 and GDAL from source, then re-compile whatever tool uses GDAL
> again?
You just need to recompile PROJ.
You can then use it in your existing GDAL (providing it links to the
recompiled PROJ) with
"+proj=bertin1953 +wktext"
(the key is to add +wktext to the PROJ string)
Even
http://www.spatialys.com
