[gdal-dev] C++ / GDAL - reading raster, exception, access violation, help please!
Tim Bodin TimBodin at comcast.net
Fri Nov 9 19:29:26 PST 2018
I sure hope someone can give me some advice.  I'm modestly experienced with
GIS and spatial stuff, but I'm trying to do rasters in C++ for the first
time.  I've been cobbling experiments together, generally successfully, but
have not consistently been able to get a raster read working, and I don't
know C++ or GDAL deeply enough to understand what to do.
Code is snapshotted below.  Using Windows, Visual Studio 2017.  If I enable
the 5 lines in the inner loop near the bottom, I get an Exception/Access
Violation on the "inDS->GetRasterBand(etc)" statement.  If I disable that
section, and specifically that line, it runs to completion without problem.
Can anyone suggest what I might try?  Thanks for helping!
#include "stdafx.h"
#include <iostream>
#include <gdal.h>
#include <gdal_priv.h>
#include "cpl_conv.h"
using namespace std;
int main()
       GDALDataset  *inDS;
       GDALAllRegister();
       const char *input = "D:/Imagery/CDLClipped.tif";
       inDS = (GDALDataset*) GDALOpen(input, GA_ReadOnly);
       if (inDS == NULL)
             cout << "unable to open input" << endl;
       int nRows, nCols;
       double transform[6];
       double noData;
       nRows = inDS->GetRasterBand(1)->GetYSize();
       nCols = inDS->GetRasterBand(1)->GetXSize();
       noData = inDS->GetRasterBand(1)->GetNoDataValue();
       inDS->GetGeoTransform(transform);
       cout << "nRows, nCols, noData = " << nRows << ", " << nCols << ", "
<< noData << endl;
       float *inDSRow = (float*)CPLMalloc(sizeof(float)*nCols);
       for (int i = 0; i < 5; i++)
             inDS->GetRasterBand(1)->RasterIO(GF_Read, 0, i, nCols, 1,
inDSRow, nCols, 1, GDT_CFloat32, 0, 0);
             for (int j = 0; j < 5 ; j++)
                    cout << inDSRow[j] << endl;
       cin.ignore();
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181109/9159620e/attachment.html>
