[gdal-dev] Fwd: Re: [Tiff] Libtiff will be released soon
Even Rouault
even.rouault at spatialys.com
Sat Nov 10 07:13:09 PST 2018
Hi all,
Due to Adobe no longer assigning TIFF tags / tags value, and someone mentionning that
the previously values use for COMPRESSION_ZSTD and COMPRESSION_WEBP were already taken,
those have been just changed:
https://gitlab.com/libtiff/libtiff/commit/126a949736fe8d2684525706e9047b39e2a095a6
I'll resynchronize the internal GDAL copy with that, which means that if you have
existing TIFF file using ZStd / WebP compression, they will no longer be recognized.
I imagine we could come with a hack to still recognize the old values, but I don't
plan to go to that complication unless really needed.
Even
---------- Forwarded Message ----------
Subject: Re: [Tiff] Libtiff will be released soon
Date: samedi 10 novembre 2018, 09:00:18 CET
From: Bob Friesenhahn <bfriesen at simple.dallas.tx.us>
To: Roger Leigh <rleigh at codelibre.net>
CC: tiff at lists.maptools.org
On Fri, 9 Nov 2018, Roger Leigh wrote:
> We could potentially do the same. Assuming the tags are allocated in a
> linear order, if we jumped all the way to e.g. 50000 we would avoid
> clashes with Adobe tag registration for some time to come. Or if Adobe
> could grant us a chunk of e.g. 1000 tags, we could manage their usage
> and standardisation ourselves.
I just submitted a changeset such that COMPRESSION_ZSTD is changed to
50000 and COMPRESSION_WEBP is changed to 50001.
Bob
Bob Friesenhahn
bfriesen at simple.dallas.tx.us, http://www.simplesystems.org/users/bfriesen/
GraphicsMagick Maintainer, http://www.GraphicsMagick.org/
Tiff mailing list: Tiff at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/tiff
http://www.remotesensing.org/libtiff/
http://www.spatialys.com
