[gdal-dev] Fwd: Re: [Tiff] Libtiff will be released soon
Even Rouault even.rouault at spatialys.com
Mon Nov 12 01:39:54 PST 2018
On lundi 12 novembre 2018 08:48:59 CET Robert Coup wrote:
> Hi Even,
> On Mon, 12 Nov 2018 at 07:57, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Not completely sure what to do with GDAL 2.3 branch, as it already had
> > ZStd
> > (if using its internal libtiff copy). I feel it is probably wise to also
> > update the modified value of COMPRESSION_ZSTD there to avoid the risk of
> > people creating files with the now obsolete tag value ?
> How about:
> 1. Read both values as enabling ZSTD
> 2. Output a warning when the old value is encountered
> 3. Always write the new value
Yeah, that's just what I have done. But only in 2.3 branch, not in master, as
I patched the internal libtiff copy for that, and don't intend to upstream
that hack or make the internal libtiff in master diverge from official
libtiff.
$ gdalinfo ../autotest/gcore/data/byte_zstd.tif
Warning 1: TIFFInitZSTD:Value of Compression Tag is 34926, which is the
deprecated value for ZStd. Please use the new value of 50000 by recreating/
patching this file. Next GDAL releases won't recognize this file.
Driver: GTiff/GeoTIFF
Files: ../autotest/gcore/data/byte_zstd.tif
Note: if you build GDAL 2.3 with the shiny new libtiff 4.0.10 as external
libtiff, those files with 34926 won't be recognized.
Even
http://www.spatialys.com
