[gdal-dev] downsampling geotiff with a low-pass filter
Marco
deduikertjes at xs4all.nl
Thu Nov 15 03:59:54 PST 2018
Upsample to 1m, then downsample to 5?
On 15-11-18 12:06, Kay F. Jahnke wrote:
> Hi all!
> I have a very detailed GeoTIFF DEM of part of my target area (2m
> resolution). The remainder of the area is covered in 5m. So I'd like
> to downsample the moore detailed data to have everything in 5m for
> further processing. The nearest thing to what I have in mind is using
> -r average, but from signal processing theory I know that using a
> simple average over a block of data is not a good approximation for a
> low-pass filter. Also, since some of the source pixels are fully
> inside the target pixels and some are only partly (5 doesn't divide by
> 2), An average over all participating source pixels seems wrong. What
> would you advise?
> With regards
> Kay
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
