[gdal-dev] Unusual RGB Tiff files with misleading	PhotometricInterpretation: valid or not?
    Even Rouault
    even.rouault at spatialys.com
    Thu Nov 15 12:20:36 PST 2018
Mikael,
> 1.  If an RGB Tiff file doesn't have PhotometricInterpretation = RGB, can it
> really be claimed that the file adheres to the Tiff standard, or is it
> corrupt?
If it has 2 values for ExtraSamples, then I believe is technically legal (the
TIFF spec is not really clear but libtiff interprets PhotometricInterpretation
= MinIsBlack as meaning one nominal channel, all the other ones being extra
samples), but of course, readers are not expected to interpret such 3-channel
files as being RGB.
> 2.  If the min and max intensities are not the same as the min and max
> representable numbers for the integer type, then how are they specified in
> Tiff?
There are MinSampleValue and MaxSampleValue tags in the TIFF spec, but those
are not really used by GDAL and are just reported as metadata.
$ cp byte.tif test.tif
$ tiffset -s MinSampleValue 1 0 test.tif
$ tiffset -s MaxSampleValue 1 255 test.tif
$ gdalinfo test.tif
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_MAXSAMPLEVALUE=255
  TIFFTAG_MINSAMPLEVALUE=0
Even
http://www.spatialys.com
