[gdal-dev] Unusual RGB Tiff files with misleading PhotometricInterpretation: valid or not?
Andrew C Aitchison andrew at aitchison.me.uk
Thu Nov 15 14:33:24 PST 2018
On Thu, 15 Nov 2018, Mikael Rittri wrote:
> When I open the files in QGIS or ArcMap, they assume RGB for the
> default visualization but I don't know why. One of the files looks
> great in ArcMap by default (but slightly too white, I believe),
> while it looks very much too white by default in QGIS, although the
> QGIS display can be fixed by color re-configuration. For the other
> file, it is QGIS that displays a sensible image by default, whereas
> ArcMap displays it with very exaggerated contrast (the default QGIS
> display is brownish-rusty like Mars while the default ArcMap display
> is brightly reddish-white like Jupiter).  So the score is 1 - 1 for
> the ArcMap/QGIS contest... I think the very different default
> displays confirm that the files are troublesome or corrupt.
Sounds like different default gamma correction values.
There are a couple of different default gamma values,
so unless the files specify their gamma, the two applications
could easily pick the right default for different pictures ...
Andrew C. Aitchison					Cambridge, UK
