[gdal-dev] downsampling geotiff with a low-pass filter
    jratike80
    jukka.rahkonen at maanmittauslaitos.fi
    Fri Nov 16 04:13:24 PST 2018
If a low-pass filter is needed before passing data to downsampling, I wonder
if it could be done by utilizing a VRT with KernelFilteredSource
https://www.gdal.org/gdal_vrttut.html. May well be that it is not relevant
at all, my understanding of mathematics coming from agricultural background.
-Jukka Rahkonen-
kfj wrote
> On 16.11.18 10:07, Even Rouault wrote:
>>> Upsampling is well
>>> covered: cubicspline and lanczos are reasonably sophisticated upsampling
>>> filters,
>> Did you actually try them for downsampling ? They are for sure widely
>> used in
>> that case already, for example when using gdaladdo to create overviews.
>> For
>> example cubicspline has a filter radius of 2. If you downsample by a
>> factor of
>> X, the effective radius will be 2 X.
> I did try them, and the result looks 'okay', but I have reservations. I
> come from a DSP background. If my understanding of the mathematics
> involved is correct, evaluating a spline over a data set will produce
> values which are appropriate at a given resolution. If you use these
> values at a lower resolution, you may get aliasing if the initial signal
> has high frequency content. Aliasing always happens if there is high
> frequency content and you resample with a lower sampling rate. You can
> only avoid it by using a low-pass filter before resampling. So I'm
> trying to find out if this does happen here.
> If I understand this correctly, the effective radius signifies the
> number of spline coefficients contributing to the interpolated value, it
> does not imply a low-pass filter. If the spline (and I suspect it's a
> B-spline) is created by first prefiltering the data and then evaluating
> the spline at the desired target locations, the interpolation criterion
> is fulfilled and there is no smoothing.
> Omitting the prefiltering and using the original data as spline
> coefficients does some smoothing, but from a cubic spline the effect is
> small and does not vary with the scale of the downsampling, so it would
> not work equally well for different scale changes.
> Maybe you can point me to the place in the source code where the
> relevant math happens? I had a look but it's very complex and I did not
> find my way in easily.
>  > They are for sure widely used
> This doesn't automatically make them correct. If my suspicions are
> founded, then there may be room for improvement.
> Kay
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
