[gdal-dev] downsampling geotiff with a low-pass filter
Kay F. Jahnke _kfj at yahoo.com
Sat Nov 17 02:04:13 PST 2018
Thank you all for responding. Rather than responding to each individual
post, I'll try and summarized what I have gleaned so far, please correct
me if I have misunderstood something. This will be a long post, please
forgive my verbosity, but this is not a trivial topic.
1.
I'll start with cubic spline resampling. Thanks to Even for pointing me
to the GDAL code. It looks to me as if the sample of the B-spline basis
function is applied directly to the source data, with no prefiltering
applied to the source data. The sampled b-spline basis function is then
used to produce a weighted average of source data values. If
prefiltering is indeed omitted, the resulting interpolation has a
slightly smoothing effect and does not fulfill the interpolation
criterion, meaning that the result of the operation at locations
coinciding with source data points does not precisely reproduce the
source data. This seems to be what's happening: without a scale change,
the application of cubic spline resampling seems to slightly smoothe the
signal.
Application of the b-spline evaluation without previous prefiltering is
commonly done, sometimes deliberately because the slight smoothing is
intended and the resulting signal will stay within the convex hull of
the coefficients (so, there won't be overshoots, which are possible with
prefiltered coefficients) - and sometimes erroneously, because the need
for prefiltering is not known. For slight downscaling, this smoothing
may be 'just right', but it's only 'about right' for a small range of
scaling factors. Note here that b-spline prefiltering is not the
low-pass filter which has to be applied to the source data before
resampling.
b-splines are not 'direct' interpolators. Direct interpolators
approximate the continuous signal by using some operation over the given
samples. b-splines instead use an operation over a set of coefficients,
which are generated from the original samples by 'prefiltering' them.
This can be explained simply: The 'reconstruction' filter for a given
b-spline is a low-pass filter. Hence, applying it to the original signal
will 'blur' that signal. The prefilter is a high-pass filter which
'sharpens' the original signal by just so much that applying the
reconstruction filter will produce the original signal. The problem with
prefiltering is that it's done with an IIR filter and has theoretically
infinite support (usually it's enough to have a handful of support
either end, forgive my sloppy formulation), which makes margin treatment
and handling of no-data value a dicey issue. This is probably one reason
why prefiltering tends to be omitted.
2.
Looking at the source code, what I understand from it is that, as I have
stated in my initial post, upsampling is indeed well-covered, but the
only 'filter' which makes sense in a downsampling context is 'average',
with all the disadvantages it has. In the GRASS codebase (Thanks to
Markus for pointing to it) I noticed that the need for specialized
technique for downsampling is acknowledged and there is a filtering
method which is definitely better-suited than just averaging over
contributing source data values: the 'weight according to area'
parameter, which can be passed to the r.resamp.stats method. This is a
technique which is also used in astronomy - I've seen it first in
openCV, where it is one of the standard interpolators ('area'). It can
produce output data which preserve the energy content of the input
signal, looking at it as if it were composed of small rectangles of a
uniform value and doing an average over a part of that pattern which is
given by the extent of the (larger) target pixel. This method is
definitely preferable to using the method without the -w parameter. It
also has the nice property of having small support and the resulting
signal will not over- or undershoot. I'd encourage GDAL to consider
adopting this method to avoid the worst of downsampling errors that come
with '-r average'.
3.
Downsampling usually has to be preceded by an appropriate low-pass
filter. Let me iterate when such a filter is needed:
The highest representable frequency in the target (downsampled) signal
is given by the Nyquist frequency for this signal's sampling rate. If
the source signal has frequency content higher than that, it *must* be
low-pass filtered before resampling, because otherwise the
high-frequency content will 'alias' into the target signal and produce
artifacts. If such high-frequency content is not present, resampling can
proceed without previous low-pass filtering.
Oftentimes the high-frequency content is small, and especially when this
comes together with small amounts of downscaling, omitting the low-pass
filter will only produce small errors which are not easily seen, so the
result may pass as correct, looking 'okay', when in fact is it slightly
wrong, but not noticeably so. With increasing high-frequency content and
larger downscaling factors, the error grows and may 'spoil' the signal
so much that it becomes noticeable.
So, first, we have to establish if there is need for low-pass-filtering,
and the advice would be to use it if there is relevant high-frequncy
content. This might be seen from an FFT of the signal. If the FFT is at
hand, the high-frequency part can be removed in the frequency domain,
and after IFFT the signal is 'eligible' for resampling without further
ado. This is a straightforward approach, but it does not play well with
no-data values. It's also possible to apply a low-pass filter no matter
if there is high-frequency content: if there is no high-frequency
content, a good low-pass filter has no effect. So now we come to the
next question, namely 'what is a good low-pass filter'.
4.
Thanks to Jakob for pointing me to your python code. I'll happily use
Python :D
Using a gaussian to smoothe (or low-pass-filter) the source signal is a
valid approach, especially since the radius of the gaussian can be
chosen to match the desired degree of smoothing, which, in a
downsampling context, depends on the scale change. Using a truncated
gaussian (the 'true gaussian' is infinitely large) as a convolution
kernel is common and well-understood. The suppression of high-frequency
content is not as sharp as one might wish; there are filters with
smaller transition bands and better stop-band attenuation, but they have
to be custom-designed for a given downsampling factor, and from what
I've seen this is not commonly done in general-purpose software.
I'd say that using a gaussian - or other convolution-based low-pass
filter is a good idea and should outperform the 'weight according to
area' method, with the downside of the wider support, which makes the
handling of no-data values more difficult. Gaussian kernels will also
not produce overshoots (because all weights are positive), which is a plus.
What has to be understood here is that the filter has to match the
desired scale change. The kernel has to be produced by a process taking
the scale change into account, which can be done for a gaussian by
choosing an appropriate standard deviation. So a general-pupose
downsampling algorithm would perform these steps:
- generate a custom filter (like, a kernel) given the desired scale change
- apply this filter to the source data
- use an interpolator over the low-pass filtered signal to obtain the
target values for the given target locations.
Not taking the scale change into account and using a fixed kernel will
only be appropriate for a specific scale change, so it's no good for the
general purpose case, but can be used for specific scale changes, like
halving the resolution ('half-band filter'), which may be repeated
several times to cover larger scale changes.
5.
This gets me to Jukka's response pointing me to VRT files with
KernelFilteredSource. I hadn't seen/noticed this before, thanks for
pointing it out! With the proviso that the kernel suits the scaling
factor (so, it has to be computed for a desired scale change) this looks
like an excellent way of dealing with the problem: The filter is
conceptually attached to the source data where it belongs, and
interpolation of target values operates on the filtered data. Neat. It
leaves the user with having to figure out a suitable kernel - a kernel
derived from a truncated (or otherwise windowed) gaussian (needs to be
normalized, though) would be a good starting point. I'll try that and
report back. It also fits well with my current work flow of using shell
scripts and gdal.
Also, thanks to Joaquim. The code you link to also looks like it will
suit the problem, but I'll admit to a bit of overload here and defer
looking at it in more detail to sometime later. What I found especially
attractive is 'grdfft', which performs operations in the frequency
domain, which is, as I have pointed out above, a very clean and
desirable way of treating the problem and should be ideal, but might be
difficult to use if there are no-data values - and the FFT and IFFT are
sure computationally intensive. I think that the GRASS code base also
offers FFT and IFFT, so it might be possible to use GRASS to the same
effect.
6.
To conclude:
- downsampling without previous low-pass filtering is normally an error.
- upsampling is a very different matter and requires no previous
filtering, it's necessary to see the distinction.
- there is a wide spectrum of possible low-pass filters, but the filter
has to be customized to the given scaling factor. There is no 'one
kernel fits all' approach.
- once the low-pass filtered signal has been obtained, it can be
downsampled using any of the available methods, but preferably *not*
nearest neighbour. Cubic spline is good here.
Still with me? Thanks for your patience! I hope I have understood all
the source code and response posts correctly, don't hesitate to correct me.
Kay
