[gdal-dev] problem with loading libraries
Ari Jolma
ari.jolma at gmail.com
Thu Nov 22 07:06:04 PST 2018
Sorry, this is not strictly a GDAL question, but it is related.
I have built postgis with raster support, which required gdal. Now, when I
CREATE EXTENSION postgis;
I get
ERROR: could not load library
"/home/ajolma/ods/server/parts/postgresql/lib/postgis-2.5.so":
libgeos_c.so.1: cannot open shared object file: No such file or directory
However, postgis-2.5.so finds libgeos:
ldd parts/postgresql/lib/postgis-2.5.so
does not show anything missing -- but it also does not show libgdal.
I have paths to gdal and other libs in LD_LIBRARY_PATH. I don't want to
make the libraries known to run-time linker with ldconfig since that
would make them global(?) and this system should be strictly non-global
in the system (there are several database servers etc running).
Any ideas what could be the issue?
Ari
