[gdal-dev] Question on how to open a raster in HDFS using GDAL
James McClain
james.mcclain at gmail.com
Fri Nov 23 13:18:35 PST 2018
Hello,
It may not be finding the native HDFS libraries. Please see the pull
request https://github.com/OSGeo/gdal/pull/714 for build instructions (in
particular, you may need to augment the LD_LIBRARY_PATH environment
variable).
If trouble persists, I would suggest building against Apache Hadoop 2.7.6
or 2.7.7 (both of those are know to work) as an experiment.
Sincerely,
James McClian
On Fri, Nov 23, 2018 at 2:15 PM ZAZHIL-HA HERENA <zazhil_ha at hotmail.com>
wrote:
> Thank you so much!, now I am working on 2.4 source code but I am getting
> an error when trying to configure using:
> *./configure
> --prefix=/scratch/zherena/gdal/build/gdal-master/gdal/outputb/
> --with-complete=yes
> --with-java=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.131-11.b12.el7.x86_64/
> --with-swig-java=yes
> --with-hdfs=/scratch/zherena/gdal/CDH-6.0.1-1.cdh6.0.1.p0.590678/
> --with-curl=/usr/bin/curl-config*
> The error I get is:
> * checking for HDFS in
> /scratch/zherena/gdal/CDH-6.0.1-1.cdh6.0.1.p0.590678/... checking for
> hdfsConnect in -lhdfs... no *
> * checking for
> /scratch/zherena/gdal/CDH-6.0.1-1.cdh6.0.1.p0.590678//include/hdfs.h... yes
> * configure: error: HDFS support not enabled.*
> Is there any configuration in my environment that I should consider? or
> maybe another distribution of Hadoop?
> *From:* Even Rouault <even.rouault at spatialys.com>
> *Sent:* Friday, November 23, 2018 11:52 AM
> *To:* gdal-dev at lists.osgeo.org
> *Cc:* ZAZHIL-HA HERENA; James McClain; nik at nikosalexandris.net
> *Subject:* Re: [gdal-dev] Question on how to open a raster in HDFS using
> GDAL
> > Version says 2.3.2 but libraries say: libgdal.so.20.4.2 .
> Libtool number (.so.20.4.2) has nothing to do with user-friendly version
> number (2.3.2)
> > I am not sure if I
> > got the latest code, this is the first time I compile it myself, I used
> > this link to download source code:
> > http://download.osgeo.org/gdal/CURRENT/gdal-2.3.2.tar.gz
> This is the latest release, but /vsihdfs/ is in the development version,
> not
> yet released, so download
> https://github.com/OSGeo/gdal/archive/master.zip
> Spatialys - Geospatial professional services
> http://www.spatialys.com
"I prayed for freedom for twenty years, but received no answer until I
prayed with my legs."
-- Frederick Douglass
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181123/969ca725/attachment.html>
