[gdal-dev] NetCDF config option for west > east?
Markus Metz
markus.metz.giswork at gmail.com
Sat Nov 24 07:27:33 PST 2018
I have a NetCDF file with west > east, gdalinfo reports
Corner Coordinates:
Upper Left ( 335.257, 70.000)
Lower Left ( 335.257, 30.000)
Upper Right ( 44.7424710, 69.9999970)
Lower Right ( 44.7424710, 29.9999954)
Center ( 190.000, 50.000)
west = 335.257 > east = 44.7424710
The reason is that west has been wrapped such that it is in the range [0,
360], and GDAL thinks that columns need to be read from right to left
instead of left to right.
The fix is to convert west with west -= 360, then assign corrected extents
with gdal_translate -a_ullr
There is a config option GDAL_NETCDF_BOTTOMUP. Could something similar be
implemented for west > east, something like GDAL_NETCDF_LEFTISLEFT? Or is
it a corrupted file and manual correction is the only option?
Markus M
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181124/fbf2f4b9/attachment.html>
